TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Any more insights/comments/hints? :-(
Subject Re: Re: Any more insights/comments/hints? :-(
Posted by edinho on March 17, 2005 at 2:16 AM
  This message has been viewed 118 times.
In Reply To Re: Any more insights/comments/hints? :-( posted by manxcat on March 16, 2005 at 11:37 PM
Message :Injector? They are designed so the fuel cools the injector which means they are susceptible to heat. My guess, the injector starts failing at operating temps. I know you have done a lot of troubleshooting and if you have truly determined that there is a lack of spark, then the injector could not be the cause, but you cannot rewire the PTU. Firing order issues and all. Dont want #1 firing when its on an exhaust stroke, burn a valve. Anyway, if it were me, I think I would swap a PTU (cause its easy) then the injector.
:J
Yeah, I figured it's probably not the injector with the ohm test and screwdriver clicking test.
Anyway, it seems to me the PTU should just be a simple solid state package that conditions the signal and/or protect the coil/ECU. I don't see any reason why it should be anything more complex than that as there is already the ECU with all the smarts. Since the impedence for the 6 pins are pretty much identical, I thought I could try swapping pins. But without knowing exactly what the PTU does, I suppose it is not a good idea. If it turns out to be the PTU, I would definitely take apart the bad one and see what in the world is inside that would cost $180! Maybe it is really simple and totally fixable so that would be useful in 2019 when everyone moans why Nissan doesn't produce parts for the car anymore. :-)
Thanks for the input.
Cheers,
e.
